Just read your other post. You have no dip stick, the fluid is checked from one of two plugs in the transmission. I would suggest you have it changed right away and hope this will correct your problem. If not you either will have a faulty temp sensor in the tranny or a problem.
Don't wait on this, tranny service and filter will most likely cure it.
Mike J.
Mike J.
