O2 Sensor multi plug destroyed
1034 Views 2 Replies 2 Participants Last post by  dismalrobot
I am replacing the front O2 sensors on my 03 Disco and found that the plug on the driver's side is shattered. There is nowhere for the new sensor to connect. Any ideas as to the easiest way around this? I am assuming I need to cut the wires and replace the plug. However, it's in such a tight spot and I don't know where I can buy the plug.
Thanks in advance for any ideas.
1 - 3 of 3 Posts
I probably have a wiring harness with an intact connector.
Cool!
Cool! If i don't find one at the local salvage yard I'll be contacting you. I was hoping to find one at a Pull-A Part lot yesterday but all but one place was closed and they only had a 97 disco in the lot.
If I find one I think I'm just going to cut the passenger side off so I have a good amount of wire to work with. Also, it doesn't look like it will be too difficult to do the rewire from the top.
1 - 3 of 3 Posts
