so after doing headgaskets on a disco 2 i came up with an o2 codes no activity, signal implausible. b1 s1. i found the connector to be a problem a long with the wiring harness. i was showing 1.125v KOEO. Ran new wires to the pcm for both the signal and ground also changed the connector. my voltage now sits at .45v. perfect, hook everything back up. Bank 2 starts switching, bank 1 stays constant at .45v. runs like **** get a heater code. run new heater signal wire to pcm. and swap Bank 2 Sensor 1 to Bank 1 because i know its working fine. still get no switching. I'm at a loss and need some help.any suggestions will be appreciated
