Obd diagnostic adapter codes
1533 Views 5 Replies 2 Participants Last post by  FFMO
Hi every one
I had rebuild my engine from the bottom to the top .but l'm facing a little vibration. ...!?! So I've used an obd diagnostic tool and this is the result
Need help what to do
1 - 6 of 6 Posts
So when you tapped the P1319 what were the sub codes?
could be spark or knock and it makes a difference. If the sub codes were spark voltage i would call a major vacuum leak somewhere in the top end throwing them all.
if it is knock related then it could possible be fuel supply or injection too but more likely a problem with the plug leads.
I would guess major vacuum leak but you need to post the sub codes under P1319.
cheers
Barri
When I cleared the codes and used the car for one hour and checked them again only the first two codes appeared
That's what's up
New update
No codes after cleaning MAF
yet the car vibrates and loosing pawor. ......what to check next?
Hello any one
1 - 6 of 6 Posts
