1 - 1 of 1 Posts
DECENDING – FIRM GROUND
• Diff lock and axle lockers engaged.
• Select low range 1st. If you cannot see the route exit, walk it first! Remove any badly placed rocks.
• Go over the edge as slowly as possible.
• Switch on the air conditioning for extra engine braking.
• Keep off the clutch and use only light braking when required.
• Slippery, off camber descents…..common problem is the rear of the vehicle sliding off to the side. This is more prone to happen when diff locks are operating.
• If a slide begins, accelerate slightly and if there is room, steer in the direction the rear is sliding. This will keep the vehicles front directly below the rear and keep the vehicle in control.
• If the vehicle jumps out of gear, stop before putting back into gear.
• Keep thumbs outside the steering wheel spokes.
• If a camper or trailer is attached, use the electric brakes to help slow down decent and prevents the trailer sliding.
DECENDING – ROCKY - STEEP
• Wet rocks can be tricky, especially if there is some mud in the spaces between the rocks. Use the rocks to advantage if possible. The sidewall of the tyre can be placed against the side of a rock to hold the vehicle and keep it from sliding sideways.
• Don’t cross fallen trees at an angle in the middle of the rocks. Drive over, square on if possible, a ‘hang up’ on the springs or differential could occur.
DECENDING – MUDDY-STEEP
• Select low range 1st. Attach chains.
• If a slide begins, accelerate slightly.
• Rutted trails can be a problem with small diameter tyres, but ruts can be a help in slippery off camber situations. If the tyres are big enough to run in the ruts you will probably not slide sideways off the hill. If the ruts are too deep, try running with just one set of tyres in a rut, if the trail is wide enough.
Sometimes the trail may have more than one track that may become icy or slippery on a descent. Try going to the side a bit to get some fresh snow or untrodden dirt under the tyres.
DECENDING – EXTREME DESCENTS
On extreme steep descents, engine braking can actually decrease control. Sometimes a hill is so steep that you will begin sliding down and low gear is too low. The tires begin sliding because they are not rotating fast enough to keep traction and control. In this case, it is best to shift into 2nd or 3rd low, depress the clutch pedal, and ride the brake. If you get into trouble, you can momentarily ease out the clutch and use power to straighten out. You need a good touch on the brakes, you don’t want to start a skid; just enough to slow down.
If the decent is so steep that the nose of truck is going to hit the bottom hard with the risk of rolling over onto the bonnet, keep the transmission in 2nd or 3rd low range, let out the clutch and give it some power just before you hit bottom. Even if the rear tires come off the ground, the front tires will pull you out of an end-over. This doesn’t feel natural, but it is the appropriate technique.
This technique works great on short extremely steep descents where overheating the brakes is not a concern. If the descent is long and engine braking is not working, pick a lower range gear for more effective engine braking.
1 - 1 of 1 Posts
