Does Fram make an oil filter? And if they do what is the part number. I looked in the Fram book and could not find a filter for an 04 Disco with a 4.6 engine. When using a 5 ton floor jack. Can I put the jack under the axle ball and use it as a single jacking point? The last time I used the 5 ton jack. I used the jacking points you would use when changing a wheel. That takes to long to get the truck up to where I can put the stands under. If I can not use the axle ball as a single jacking point. Where would I find a single jacking point?
