I am going to look at an 03 tomorrow that falls within the specified vin range and I was wondering......
1) Where do you hook up a gauge to test the oil pressure
2) what should the numbers be for all four readings
3) if I were to buy it and either replace the pump right away or if the oil light were to come on and I shut it down right away, would I have to replace the gear and the cover or just the gear? There seems to be about a $400-$500 difference between just the gear and the entire assembly.
