1 - 4 of 4 Posts
For the first time in ownership of my '01DII, I heard the most horrific noise coming from the front of my rover: a squeaking sound when moving my steering wheel.
It's not power steering-related, but I fear that it is a looming ball joint failure from my front axle. When I last looked, the rubber bushings at both left and right front wheels were rather dry and worn, so it's time to replace them?
Has anyone had this replaced/repaired? Any other suspension-related items I should fix as well?
And I think I may need an alignment too along with a new steering damper.
Automotive exterior Bumper Vehicle door Auto part Tire
How many miles on that Disco?
As for the noise, might want to remove your belt and spin each pulley to see if one is failing.
I would worry much about an alignment unless one of the outer edges of one tire is warn badly, also you can only do a toe adjustment.
When was the last time you did a major service like the one posted at the top of this section, have you rebuilt or replaced your front drive shaft?
Hey Mike.
I have 140K on her. And yes, my front tires are showing a little uneven wear towards the inner -center walls.
Yes, I've done the major service. I *just* found a shop here in Dallas recommended by another DII owner. I'll be doing the r/b in just a week or so. Until then, I'm driving with the CDL engaged.
By the way, what are the parts I need to replace those parts on the wheel? I already know about the drag link and the track rod, but what about those bushings right at the wheels?
1 - 4 of 4 Posts
