1 - 5 of 5 Posts
hi ive being trying to use my 109 deasal for work a lot more its a 110 mile round trip .some time ago i replace the temp sender becos it did not seem to go up since then it gos up a bit too far ive got a kenlow type fan which when swicthed on the temp was just befor the red but no water loss all seemed ok util it lost a blade and started shakeing the motor to death so i refitted the old blade metal water pump standard fan temp still gos just b4 the red and up hill gos a bit higher but no steam or water loss any idears?? :dunno:
Series Moderator
sounds like the thermostat has failed stick a new one in
First thing I would do if an electric guage is telling you there is a potential problem, is check the temp with a probe thermometer to be certain it's actually as hot as the guage says. A bad voltage stabilizer will make your guage read high, if your guage is getting more than 10.5 volts.
Assuming there is a high temp problem, get your rad flushed, block flushed, and for heaven's sake, put a new thermostat in. Diesels need a proper, regulated operating temp
1 - 5 of 5 Posts
