1 - 2 of 2 Posts
Some would say OK. Can't you drain a little? If you drained from below, just crack plug and drain a little. If you are a snail driver until the next change it might be fine. But, if you like to pedal it a little I would drain some to be on safe side as engine is not cheap.
1 - 2 of 2 Posts
