Year:1990
Make:Land Rover
Model:Range Rover
Mileage:203000 M
Transmission:Automatic
Engine:3.9
Trim:County
This Rangie was prepared for long distance overland expeditions but I’m on to other things now.
Suspension: A soft-ride 2” lift but it comes with a set of HD 2” lift springs from ARB for when you load it up for long trips. It has a shock extension kit from Safarigard and extended bump stops, stainless exhaust, low profile thick-wall bumpers front and back (front has a mount for the highlift jack), front skid plate, safarigard front diff guard and radius arms, polybushes. Front castor correction kit.
Drivetrain: Upgraded for 32” tires; 4.11 ratio diffs, 24 spline half shafts, ARB air pump with ARB lockers, GBR front double cardan drive shaft. The ABS has been professionally replaced with a vacuum servo balanced braking that works worlds better off-road. Wheels are the alloys from a Defender. It comes with chains.
Running condition: I drive it every day. The engine, transmission, transfer case etc runs well with no warning lights. Radiator has a slow leak. MT tires are lumpy with wear but still have safe tread. The water pump, belts and most hoses were replaced last year.
Interior: Windows, locks, seat motors, sunroof all work. Sunroof does not leak. Was a CA car until I purchased 10 yrs ago- just a little surface rust on floors- no holes or blown seams- could use cleaning and re-coating but not urgent.
Other: The aluminum body is straight but paint is in thin in some areas and the passenger front door has an area where paint has chipped (see photos). AC compressor has been removed. Front floor carpets have been removed. Has a dog fence for safety.
Spares included with the purchase:
New old stock parts:
  • RTC 4653 transmission filter kit with gaskets/ o rings
  • RTC 4268 transmission pan gasket
  • QWB706 2 kits; front wheel bearing kits
  • STC1184R Ignition module
  • ERR2958 timing chain sprocket (small)
  • 610289 Eurospare large timing chain sprocket
  • ERC7929 timing chain
  • Engine front cover gasket
  • Universal joint bearing kit
  • ERR1632G engine front cover oil seal
  • 96680 (2 pcs) brake rotor front
  • DA2499 (2 kits) door lock button kits
Used parts: Spare suspension springs (ARB HD), front propshaft, tail light guards, AC parts, various vents, switches, servos for locks and wipers, interior trim pcs; it’s a large bin of parts. I can take pictures if needed.
Overall this is a very well balanced rig that needs a radiator repair, a new enthusiastic owner and a full itinerary of trips ahead. It is priced well for its condition and for how perfectly it’s set-up.
