1 - 8 of 8 Posts
Discussion Starter #1
04 D2.
Misfire 1 and 5.
Any pro tips on starting diagnosis?
Thanks. Appreciate you, as always.
Expert Crate Digger
Check your spark plug wires and boots. I had two boots crack and cause misfires. Also the spark plugs.
This!
you can swap plug wires with 2 & 6 to verify the misfire.
Discussion Starter #4
Gotcha on the wires & plugs.
The oddity is: i cleared the codes the other day when i first posted this and they still haven’t come back and it’s been driven regularly.
Theory: gas cap is often (in the az heat) hard for the mrs. to get on completely (which i tightened down,too, when i posted this the other day) and routinely throws the gas cap evap code.
Could the misfire codes and gas cap evap be related?
Expert Crate Digger
With these Land Rovers, anything is possible.
In my experience, that evap code is sometimes partnered with the misfire codes. Of which a scatterbomb replacing of correct O2 sensors, wires and plugs magically fixed those and other codes.
Usual suspects are wires and spark plugs however I had misfires associated with O2...these Discos
Also cannot rule out a coil pack that split.
Buttttt, not trying to be silly here, is your Frau throwing in the right gas? I had a similar misfire issue when I was messing around with lower octane gas (my other disco handled it no problem, this disco however is another story)
Discussion Starter #8
Well the code still hasn’t come back yet.
We’ll see...
And
Yes Fraulein is putting in the right gas - it’s a valid/good question to double check.
1 - 8 of 8 Posts
