1 - 5 of 5 Posts
Try cleaning the throttle body
Thank you for responding. I did clean the throttle body , it is a discovery sport 2016 . I replaced the valve cover and the oil separator on the side wall of the engine, I replaced the belt tensioner as well. The engine idles rough . It drives well except it idles bad and sometime will stall. It had timing faults , I did the timing components on it and replaced the vvt . no other fault.
Pierre
1 - 5 of 5 Posts
