5/96 discovery 1 se7 4.0l
105k miles on the truck
new fuel pump assembly 40psi pressure while running no change when hot
fuel filter replaced
ngk 6es copper plugs with 8mm sti wires
4 new coilpacks
upper intake has been taken off thoroughly cleaned and rtv resealed
fuel rail taken off cleaned new bosch/mustang 19# injectors all new orings no leaks
motor looks clean inside shell 15w40 with napa gold oversized filters used
new air filter all hose clamps checked and turned
maf and iacv cleaned
sprayed the engine all around with 3 cans of ether with no change in rpm
havnt had the truck that long, starts right up hot or cold and drives well when up to speed(over 30)
vss is good
here is some freeze data hopefully someone can help identifying a problem
p1316
rpm 1180
load value 33.7%
coolant temp 210
short term fuel trim(1) 1.0%
long term fuel trim (1) 5.1%
short term fuel (2) 12.1%
long term fuel(2) 5.1%
short term fuel trim(3) 100.6%
long term fuel trim(4)100.6%
vs 11mph
fuel system 1 clsd
fuel system 2 clsd
erased the code drove it 5 miles down the road
p1316
rpm1459
load value 36%
coolant temp 194
short term fuel trim(1) 6.3%
long term fuel trim (1) 0.7%
short term fuel (2) 11.8%
long term fuel (2) 0.7%
short term fuel trim (3)100.6%
long term fuel trim (4)100.6%
vs 16mph
fuel system 1 clsd
fuel system 2 clsd
Truck starts right up everytime easily. seems to run slightly better while cool. Has a nice lope at idle, bliping the throttle past 2k rpm smooths thing out. No overheating plugs dont seem to be gas soaked and are clean gapped at .038. tested a new crank sensor without change. o2 sensors might be the next on the list.
any ideas???
4 new coilpacks
vss is good
p1316
rpm 1180
load value 33.7%
coolant temp 210
vs 11mph
fuel system 1 clsd
fuel system 2 clsd
p1316
rpm1459
load value 36%
coolant temp 194
vs 16mph
fuel system 1 clsd
fuel system 2 clsd
any ideas???
