1 - 5 of 5 Posts
I'm new to Rovers, so please forgive my lack of knowledge. I've been getting P1412 and P1415 codes popping up. I first thought it was something related to something I did when I was installing my lift. I went back through everything I did, checked to make sure nothing was loose, and erased the codes. After about 400 miles the CEL came back on with the same codes. The SAI pump does sound like jet engine, and all the hoses seem to be OK.
Any ideas besides telling me to go to the dealer? If you're going to tell me to go to the dealer then please don't comment. I'll be doing all the work myself, just need a little guidance since I'm new to Rovers, but not to working on cars.
oh man, you are going to have to go to the dealer. :)
just kidding - i hope. most of us that are here or other LR forums. we like to work on our own trucks. :)
P1412 SAI Malfunction Bank 1LH (Insufficient SAI flow during passive test)
P1415 SAI Malfunction Bank 2RH (Insufficient SAI flow during passive test)
Here are a couple threads that might help you out...
http://landroverforums.com/forum/discovery-ii-18/p1412-p1415-codes-loud-sai-45752/
here is a thread on 1412 and 1415 codes. it says it was solved. hope it helps you.
Code: P1412 & P1415 Issue SOLVED? Pictures! - Land Rover Forums - Land Rover Enthusiast Forum
or
http://www.landroversonly.com/forums/f40/sai-codes-hi-temp-36635/
and
http://www.discoweb.org/forums/showthread.php?t=33120
i posted a couple more links just after you quoted the first post. hope one of them will help you out.
i dont have a SAI pump so i have no experience working with them. :(
1 - 5 of 5 Posts
