1 - 2 of 2 Posts
Getting a p1590 code...from reading other posts, is it wise to start with the brakes if they are squeaking?
Autozone reader says its neutral position switch but OEM brand says Subraru. so that was a waste.
Thinking about getting a icarsoft i930 scanner....anyone have one? what are your thoughts if you do? i would like to be able to get proper readings and be able to remove codes after i do work on the Disco.
Joe Btfsplk
P1590 code
Disco Marek:
You can't clear a 1590, until you repair the brake problem which means you need to have the correct scanner read the ABS code, fix it, then clear the codes at which time the 1590 will also go away.
Sorry. Wish I could help more. Do check the site I reference below!
(I have used the Hawkeye only, can't comment on the icarsoft scanner.)
Check this site; http://landroverforums.com/forum/discovery-ii-18/obdii-code-p1590-58249/
1 - 2 of 2 Posts
