Hi
Ihave a 1996 4.6 hse which has a brc autogas sequential system fitted and have only been able to cover 40 miles in the last 5 months because of running problems.
It started with what i can only describe as a pinking noise from the drivers side bank of cylinders, so i took it to a so called expert who replaced leads and plugs, which i had already done and said the car was ok. i picked up the car and on the way home it was still pinking.
i had to park the car for 5 weeks and tried to start it only to find it was not running on all cylinders and popping back through the exhaust i got about 1/4 of a mile before it stopped. so back to the expert for some rovacom diagnostics and more leads and plugs, fuse box,2 x fuel pump relays, fuel filter, crank sensor, airflow meter,altenator, nad a bill for nearly £1000 it had taken 3 weeks before this i had replaced the valley gasket in a bid to cure the pinking as it seemed to be drawing water from the rear waterway into the rear cylinder on the driverside bank , so i picked up the car and it started ok but on the journey home it was missing between 2000-3000 rpm and the expert assured me it was some stale fuel even though he had put £40 worth of fresh fuel in after draining the tank. i then took the car for a mot test and had to replace the middle exhaust section but the emmisions were through the roof on both gas and petrol so the mot station replaced the lambda sensor and then it started playing up again not starting or when it did it would not rev more than 1500, so new coils were fitted but were no good so a second set were fitted and it was running again unfortunatly it rained and it reverted back to not revving more than 1500 rpm which results in the car popping back through the exhaust and coming to a stop after 3 or 4 minuits. i did a compression test and it read 175 on all cylinders dry but the car is now sitting on the drive again and has cost me a total of £2700 for approx 40 miles has anyone any ideas the mot station think its the ecu but im not convinced.I have also replaced the battery last week as the old one had a cell down.
