1 - 8 of 8 Posts
So I unhooked the pin holding the parking brake cable to i can take the centre console out.
Well, i hooked it back up by i do not hvae any spring on the button on the brake lever. any know what i did wrong or did i lose a part?
take care
sam
· Super Moderator
Disco 1 or 2?
· Super Moderator
All I could find is the following (without illustrations)
Parking brake adjust
1. Select a gear or ’P’ in main gearbox.
2. Chock road wheels.
3. Release parkbrake lever.
4. Remove switch panel from centre console.
5. Underneath vehicle, rotate brake adjuster
clockwise until brake shoes are fully expanded
against drum.
6. Back off adjuster until drum is free to rotate.
7. Rotate adjustment thumbwheel below parkbrake
lever until parking brake is fully operational on
third notch of ratchet.
NOTE: Cable adjustment must ONLY be
used for initial setting and to compensate
for cable stretch. It MUST NOT be used to
take up brake shoe wear, which MUST be adjusted
at brake drum.
8. Operate parking brake to settle shoes. Recheck
parkbrake is fully operational on third notch of
ratchet. Readjust if necessary.
9. Refit switch panel.
Enjoy
Ryan
dent said:
thanks, the problem i'm having is the spring/ latch mechinism. the latch will not set and when i push the button in, it does not pop back out
take care
sam
If i understand your description right,what's happened is the rod from the button to the ratchet has a slight bend in it,this can happen if the lever has been pulled back too far. All you need to do is get a thin-ish screwdriver in through the raer of the lever and gently bend it back a little at a time and try it.
Hope that makes sense!
Mick
1 - 8 of 8 Posts
