1 - 13 of 13 Posts
Have the whole thing...start naming parts....
Tranny is bad.
Plug wires gone.
Front marker/turn signal lenses gone
Pass/rear signal gone
rear 1/4's are rough
RJ
Missing door 'panel'
Hi TOZROVR,
I'm looking for the rubber door 'panels' on the passenger side for my 88 RRC. Attached is a cropped picture of the missing 'panel' on the passenger side and another pic with the driver side panel still in place.
Does your 88 have these two pieces?
Thanks,
Drew
Hey RJ...
Are you still parting her out?
If so, I need a fan clutch, oil level sensor, and speedo if the odometer works.
thanks
Discussion Starter · #5 ·
DrewInSD said:
Hi TOZROVR,
Thanks,
Drew
Drew I have them but they look like this....
RJ
Drew:
You could buy the whole rubber side panels from TOZROVR and upgrade yours to "chromed trim" side panels.I think they'll look nicer too.Just my opinion.
Carlos
Wiil the parts fit a 1990 Range Rover?
I am a new owner and would like to get some parts for my 1990 Range Rover. Serial Number is SALHV1241LA403423
The parts that it needs:
1. Headliner (Sorrell Brown leather interior)
2. Code for the alarm system, so the radio will work
3. Driver’s side;
*Outside door handle
*Bottom of door molding bottom (aluminum, not chrome) 'kick plate'
*Wooden trim just under window
4. Front driving light lens for driving light
5. Passenger's side
*Seat control (wedge shaped)
*Seat bottom
6. Rear hatch back bottom section. (there are 4 sections)
As I say, I am new at this, so any help would be appreciated.
b
87 RR Classic 3.5 water temp sensor unit for gauge
Hello, would you have the water temp sending unit for the RR 3.5 motor? There are three, large one for the fan, two prong for the ecu, one prong for the gauge. The gauge is the one we need.
Thanks, Mike
Center Console needed......
What part of your console is broken?
1 - 13 of 13 Posts
