Hi Guys.
First quick background.
Son was given (as in free) a pristine 2004 D2 (120K mile CA vehicle) with a slipped sleeve.
We pulled engine and did a total rebuild, starting with top hat sleeves and all the way down to polishing the crank.
Stupid as it sounds, though we replaced everything else, we did NOT replace the PCV/oil separator. We tried to remove it, it would not come out (easily), so we just left it. We even removed the baffles, did a full Berryman dip of the covers to remove all varnish (solvent ran straight thru the PCV) and even took it to a buffer wheel polished the outside to a chrome-like shine, but didn't remove the PCV body. Crazy stupid I know, but that's what we did.
Well, after 3,000 miles we have a leak at the what appears to be the rear seal. At the advice of the shop that re-machined the block and pressed in the flanged sleeves, we used genuine Land Rover parts for the front and rear mains and the cruxiforms (at 4-6x the cost of aftermarkets). Even used the Roll Royce Aircraft engine speced hylomar (sp?) sealant at $25 a tube. The rear main bearing cap fit very snug: it had to be tapped on with a mallet and piece of wood.
As we were so careful with everything except the PCV, I am wondering (hoping) whether we have pressure build-up from a blocked PCV that is causing the leak. There is NO leak at the valve covers, front or sump seal or anywhere else, just thru that "crack" at the bottom of the engine where it meets the bell housing.
So a couple of questions:
1. What the probability that pressure buildup in the engine might be the source of our leak?
2. Is it reversible? If we correct the pressure, will the rear seal "recover"? or once it is distended by pressure and fails, it will never return to its original state?
3. I have read that these PCV bodies break pretty easily, does anyone have a "trick" to removing it? Is it just held in-place with an o-ring on the valve cover or is it more complicated than that?
4. I can't seem to find a replacement PCV "body", only a replacement for the oil separator that fits inside the body. Does anyone know where I can get a PCV body as I want to be prepared when it breaks.
Any help/advice would be greatly appreciated.
