Well, until you get under the hood and under the truck to see what is leaking, all we can do is guess.
Check it out and get back to us with more information.
Yeah, def check there. That hard plastic tubing gets really brittle. Also might explain the intermittentness of your problem too, having to do more with the reservoir piping.I'd suggest looking at the small hoses that run from the expansion tank to the throttle body housing and the one that runs to the top of the rad.
I had a similar issue and only found the leak once I had disconnected these hoses to find the rubber had perished but coolant loss was minimal.
The one that leads to and joins the radiator is hidden under the Fan plastic cowling and you need to remove this to get a proper look.
Cheers, Jerry
