Gillah11 said:didn't figure an old picture of me would peak anyone's interest!
If you are hot, you can always turn on the air conditioning.roverX said:So...you're saying you're a chick? Are you hot? :beer:
Disco said:Well, I bought it for $1000 bucks and had to travel to Colorado (yeah, that didn't suck) to pick it up. She's pretty much stock for now... 162,000 miles and only some minor wear and tear in the interior. Overall she's in great shape for her age and I can see this is the beginning of a beautiful relationship.
I would fix the wires, if they are severed then that is your problem. Easy fix...Gillah11 said:Couple of questions for you veteran RRC's out there though... Since I brought her home, the coolant/radiator light has begun to continuously "blink". Now I'm not overheating (the temp guage reads very normal), the fluid in the overflow tank is plentiful but I have noticed that the "wires" leading into the top of the overflow tank cap have corroded and severed off. Is this causing the annoying blinking, or is there something else I should be looking for. If this is the cause, is there a cost effective **cheap** fix?
Also the vent lever that moves the air from your feet to your windshield is disconnected somehow inside and the levers are stuck blowing heat on the windshield. Is there an easy way to get to the guts of the ventilation system to reconnect it?
Your insight will be much appreciated. Thanks!
The light blinks when the coolant is low. Since your sensor isn't there, it's no doubt thinking your coolant level is low. If you reconnect the wires the light should turn off.Gillah11 said:Since I brought her home, the coolant/radiator light has begun to continuously "blink". Now I'm not overheating (the temp guage reads very normal), the fluid in the overflow tank is plentiful but I have noticed that the "wires" leading into the top of the overflow tank cap have corroded and severed off. Is this causing the annoying blinking, or is there something else I should be looking for. If this is the cause, is there a cost effective **cheap** fix?
Well..... I drive a Rover don't I?roverX said:So...you're saying you're a chick? Are you hot? :beer:
Up in Loveland. I have family there, and they clued me in on it.Funrover said:Where in Colorado did you find that?
Gillah11 said:Well..... I drive a Rover don't I?
Good catch by the way!
Fine, here ya go! You guys decide!Funrover said:Why didn't you post a pic with you and the rover?....Keep on rovering
