1 - 6 of 6 Posts
Discussion Starter #1
I have a 95 classic I disconnected the air system and put springs that gives it a 3 inch lift. I read that they came with air lockers I was wondering if this is true? I followed air lines that went to both axels. so I was wondering since I disconnected the air system that I don't have air lockers now since I disconnected it??? if so how can I rig up the system to connect them again? do I hot wire the compressor and hook up both lines directly to the tank?
thank you,
jesse
Rover-Holic and Admin
Range Rover Classics never came with Air Lockers from the factory.
Like Jafir said they are probably your axle breathers.
1 - 6 of 6 Posts
