I have a 2003 disco II and I am trying to find out what the tapping noise is when it is warmed up. I have been reading your posts and feel like you might be the person who can help. the problem is that I have looked at everything and still can't find the problem. First thing I did was check the oil Pressure which was very good. I then looked at the valve train and replaced the lifters and the cam because they were worn. still tapping while warm. I then read the post about sleeves and decided to look at those, while I had the oil pan off I replaced the rod journals and the crank journals, no sign of sleeves moving. is there something I am missing? my next thought is to replace the rocker arms and push rods. I would appreciate any help you can give.
