Ladies and Gentlemen Im back with another issue.
I have a1993 range rover county LWB, I purchased another Seat ECU with the memory function and I also removed and cleaned my seat switches. The problem now is this: I can not take out the existing ECU . I have disconnected all of the connections excet the wide one. I was able to use speaker wire to raise the seat and move it back but that last connection is held up by some sort of clip and also the area where the tab needs to be depressed is covered by the seat frame. I can not get to it and dont know how to remove the clip without damaging the connections. My only option is to cut out the connections from the old ECu but i still wont be able to get to the clip. HELP!!!!!! !!
