The potentiometer and TPS are one and the same, just different terms to describe it. Earlier EFI engines (yours) used Lucas 14CU computers, but the 14CUX (developed for the US market) eliminated the adjustment of the TPS, so when it goes on, in won't rotate. A rouugh running spot in the rpm range is a good indication of a TPS with a bad spot in it's winding. It's just a variable resistor, like a volume control pot (potentiometer) in a radio. The spot in the winding most often hit, idle and cruising speed, is usually where it breaks down. The Ign. amplifier, mounted to the side of the distributor, does break down with heat related aging. It is intended to act as a switch, like an old set of points, getting it's impulse from the Hall effect pickup coil, which can't handle the current of a ign coil. They almost always just quit, no inbetween. Often the truck will start when cold, but as soon as it heats up under the hood, they pack it in. Pick-up coils do occasionally go, but more common is a break in the flexible wire from the pick-up to the side of the distributor where the amp lugs in. This is beacuase of all the flexing it does when the advance unit rotates the breaker plate (everytime you step on the gas).
