OK guys….here's one for you. I found the power steering pump to be leaking on my Disco 2. I replaced the gasket between the halves of the pump housing. When I re-assembled it, it started off working fine. I was in the process of bleeding the air from the system, when the groaning sound returned. When I stop turning the wheel, i can hear (what I believe) to be the sound of a bearing issue with the pump now. Am I heading in the right direction on this, or will a lot of air in the system lead to the sounds I am hearing? Thanks in advance for your help.
