Last eBay Disco we had in our shop required over $2K in work just to be considered safe to drive and left with a list of upcoming repairs that will be needed in the next 6 months (or at least before emissions inspections) that total another $1500 or so.
Common 95 Disco problems:
rust- look around striker pins on the rear side door jambs, and under carpet in foot wells
Leaking power steering lines- they ALL do it unless repaired recently
Abnormal valve noise from engine
Broken distributor- unable to set base timing and hold it
neglected x-fer case and axles. People seem to 'forget' they need fuild changes
Rear windows inoperable or intermittant - they have their own ECU and they fail a lot
If over 120K, should be on recent alternator and water pump/tensioner or plan on them sometime soon
CDL linkage inop- often will go from hi to lo, but CDL lock/unlock is often frozen
Brakes can be expensive if the calipers or rotors need replacement
Swivel balls and CV joints- any noise in the CV's can mean $400 per side in repairs (parts only).
There's a few other common ones... but there's a start!
