Muddy Oval said:
I think a 1" spacer to level a truck running stiffer aftermarket springs is fine- sticking tall spacers on stock springs is not...
I still think it reflects poorly on OME that they suggest a spacer instead of getting a proper spring instead. There are plenty of 3" springs available. I don't think too much of OME anymore.
..hehe...they dont suggest a spacer. Actually I called ARB and they said that they strongly recommend not to mix springs or shocks and not to use spacers, etc....anything past normal design which would be 2" springs and shocks for the correct model.
For the OME 3" "custom" lift you use Discovery I springs in the front (commonly 751's) to raise it 3", and then a regular discovery II springs (781)in the rear but require a spacer to compensate.
....the problem is that eventhough this is a good setup....it leaves you with 2" shocks on a 3" lift. Because of this the vehicle is in more of a risk of overextending the shocks because unlike the DI, RRC, D90, there is no way of relocating the upper shock mounts on a DII lower without welding, etc. Thats why after breaking 2 OME shocks because of this exact reason, I am going with Bilstein 7100 long travel shocks. The 10" of travel will be more then enough and will compensate for the lack of ablility to lower the shock mounts.
