I got my 94 Classic 3.9 in June and have had a ton O' problem since.
I need ideas on where to check next!
Currently it will start, but as soon as throttle is applied it will sputter. If you can play with the throttle you can get it up to speed, but soon as vehicle slows to stop it will die. It will idle but only just after starting and only in neutral or park.
Since I got it I replaced:
All fluids & filters
Plugs
Wires
Cap & Rotor
Base plate and pickup
Amplifier Module (remote style)
Coil
Injectors
Fuel temp. sensor
Coolant temp. sensor
fuel filter
stepper motor (idle air bypass)
Oxygen sensors
Cleaned:
Flame trap
MAF sensor
complete brake job
air filter
So the only thing I think it could be is blown head gasket, and I have'nt checked the Fuel pressure regulator.
ANY IDEAS???????????????
Plugs
Wires
Cap & Rotor
Coil
Injectors
Fuel temp. sensor
fuel filter
Oxygen sensors
Cleaned:
Flame trap
MAF sensor
complete brake job
air filter
