1 - 5 of 5 Posts
Going to need to remove my front prop shaft to be rebuilt. According to RAV it's as simple as removing the 8 bolts. Then to replace just bolt it back up. Is it really that simple or am I missing something?
certified idiot
just remember to mark both front and rear joint so you can put the rebuilt one back in the same relative position. I use an angle grinder to make a small groove across both parts of the joint.
cheers
Barri
It's simple, but can be difficult depending on condition of the bolts and nuts.
To prevent rounding them off, ideally loosen them with a 6pt box end wrench, then use an open end to finish removing them.
I never mark them removing them if I'm rebuilding them or installing new. But if you want to, a center punch is better than cutting a groove in the flanges, and a lot easier also.
Whether you're doing it yourself or having someone else do it, you may want to read this post:
http://landroverforums.com/forum/general-tech-help-8/propshaft-rebuild-29302/#post164811
I just did this in June and it is that simple. I had the time to blast the nuts with some WD-40 to "unstick" them for a few days before I started. Had no issues with bold or nut rounding - just a cracked socket. Installed a new one from the guys in Utah. Whole job took just over an hour.
1 - 5 of 5 Posts
