1 - 7 of 7 Posts
LANJ66
Discussion Starter #1
Hi dudes.... does any body knows if this scan tool works good on Lnad Rovers? (abs, srs, etc)
Administrator
99% of all scanners will not work on ABS, SLS or SRS codes, those require special scanners in the $700 plus price range.
LANJ66
Discussion Starter #5
txxs mike!
It won't dig that deep into your systems but if it's anything like elmscan5 then it is pretty good. You can run different software that is readily available on the internet. It will show real time data (great for trouble shooting sensors!) as well as freeze frames.
Get this and the ABS Amigo and you should be pretty much good to go.
LANJ66
Discussion Starter #7
Txxs Again!!!!
1 - 7 of 7 Posts
