Drewfuss said:
Thanks for the reply! Another question, is the V8 rebuildable? Obviously any engine is, but is this V8 capable of being rebuilt without costing thousands? I suppose I'm just trying to see what I'd be up against in the future if I were to purchase such a high milage vehicle.
Yes, the engine is very rebuildable. I just did a 4.2 from scratch, so costs are pretty well known. Figure on about $800 with machine shop work. Boiling out the block, plane the heads and install the cam bearings are jobs best left to them. Cam bearings are extremely soft, and require tools for each size (there are 4 different sizes)
Parts to buy: Cam, Lifters, Timing chain and both sprockets, Rings, Main & Rod Bearings, Top end set (includes gaskets, stem seals, injector "O" rings, new headbolts). Front & Rear seals.
Other parts that MAY require replacing:
Oil pump gears, Valve Guides, Starter ring gear, water pump (cheap insurance)
Have a good, clean work environment, an engine stand, CLEAN tools, and about 16 hours.
Shop around for your parts, you would go broke buying them from the LR dealer. Genuine LR cams for a 3.9 were known for soft heat treatment, and shorter than averagae life . I don't reccomend going to performance parts unless you want to spend more $$. Crane makes several different grinds patterns, but they all require changing valve springs and milling the spring pockets in the heads. Oh yeah, did I mention removing all the valves, cleaning and lapping them, keeping the valves and springs in order.
There is one brand of piston rings which I strongly reccomend, but I can't remember their name at the moment. They are 4 piece in staed of 3, like factory and have better scrapers. When replacing the rings, clean the ring grooves thoroughly, they will be carboned up.
All of the above is pretty much the basic minimums. Other considerations will be when you check the crank for wear, and the cylinder bores. If the crank requires grinding (in increments of .010") oversized bearings are used. If the bores are severely scored, they may need boring, also in increments of .010" and oversized pistons (& rings) will be needed. This is where you really need to weigh the choices of a new shortblock or proceeding with a rebuild. The supply of new 4.0 shortblocks is eventually going to dry up, but at those quoted prices of $1400-2000, they're pretty inviting.
Oh yeah, forgot to mention, replace all freeze plugs and oil gallery plugs, that's pretty much a given since the machine shop will have removed them when they boiled and blew out the block.
