My radiator leaking from Top screw. I saw some post about sealing with slow-set JB weld. I did that for temporary fix and ordered a radiator. My 2001 Disco has 60k mileage on. I never had any problem with the cooling system.
I am thinking to replace the water pump, hoses, T-stat, belt. They are all original never been changed. The waterpump bolts look very rusty. I feel i need to replace those since I will be opening up the whole front.
anyone recommend getting this water pump? WATER PUMP
Has anyone bought parts from here?
Jaguar Parts | Land Rover & Range Rover Parts | British Parts UK
Do you have any recommendation on these parts, brand etc? Should I even change these the waterpump, belts and hoses? :help
Will appreciate any advice. Thanks
