1 - 2 of 2 Posts
Hi everyone
On the subject of 'radio resetting'...I just bought a 2000 Range Rover and the radio doesn't work (of course!). It doesn't even turn on/light up. All the associated fuses are good, including the one in the rear of the radio chassis. Any hints or cures out there?
I assume you have checked there is power to both the pink and red wires? If you have power there, unplug the head unit and let is sit disconnected overnight. This will clear any memory faults. Then reconnect and try powering up again. However, it is more likely to be a fault inside the unit that will require a technician to repair it. It should not be a very expensive job
1 - 2 of 2 Posts
