Hello cas,
I feel your pain
I am having simular fuel related problems at this time, try first to put gas into the tank, at start up, let the key stay at the ignition on position, you should hear a happy whirring sound from the rear of your disco of the pump working.
If so let it run until it locks off. repeat this process a couple of times, then under the hood on the spray bar you will see a valve cap( just like for a tire )for the release of fuel pressure (discovered this when recently replacing my fuel pump) VERY gently press the valve in with a small screw driver, etc... and see if you have a good squirt. get an amount of cloths ready to mop up the spare fuel.
If anything, you get just air then at least you are bleeding out the air from the fuel system and you will eventually get just fuel.
I found this worked for me, I hope this is good advice for you, If anyone else can develop on this please do.
Good luck,
John.
