Hi, I have a 2005 RRS Supercharged that drives perfeclty through the gears if driven steadily, if I drive quicker the gearbox holds onto 4th gear until 6000rpm. Obviously I don't want to drive it up to those revs so I change the gear up manually to 5th and all is good again, the change from 5th to 6th is perfect. Another option I can do is switch on cruise control when it holds in 4th, it then instantly changes into 5th and then 6th as it should. Some days this doesn't hold in 4th but most days it will. Any suggestions welcomed
