Robrover said:
I love my Rover on smooth highway pavement but when the road has imperfections I get rattling coming from the rear. Its definitely coming from the hatch is there anything to do to get rid of the noise? I was thinking lithium grease on the lock mechanisms. Any remedy would be appreciated. Thanks.
Hi Robrover, open the upper tailgate but leave the lower closed. Try moving the lower half,i suspect it will move on the striker plates causing the rattle. If it does,open the lower and try adjusting the striker plates toward the front of the car slightly to make a tighter fit when shut. Once happy with the shut,check the upper still closes ok and hopfully road test a non-rattling P38.
Oh,you may want to oil the lower tailgate latches while you are there,the often show signs of corrosion and can get a bit 'sticky'.
Good luck,
Mick
