1 - 7 of 7 Posts
Gents,
To my dismay, when I went to get aligned (don't worry, I amped out in their garage during the whole thing) on the 4 wheel rack, My rear axle alignment is off by 1/2 a degree.
I talked at length with the guy about it and he said that to adjust the front would be straight guessing without the rear being on.
I was thinking worn bushings?
Ideas, experience?
· Premium Member
Good possibility of a warn trailing arm bushing.
Well crap, not too bad it doesn't look like to replace, except that I don't have a press...
Is it possible that the watts link could also be throwing this off?
Between this, and my cdl install, the rover is getting lots of love these days!
· Premium Member
I don't think it is the watts linkage. How does the truck drive, how about rear tire wear? Don't attempt to replace the trailing arm bushings unless you have a 12 ton, press.
Discussion Starter · #5 · (Edited)
Rear wear is fine, nothing out of the ordinary. Maybe I'll have a go at aligning it myself this weekend.
Here are my current numbers:
Front
Toe L -.60 R .23 T -.37
Rear
Roe L .44 R -.52 T -.08
Thrust Angle -.48
Any suggestions/tips?
Truck wanders a bit and pulls left, but I also have a caliper that is sticky on that front left wheel. Rebuilding that this weekend also!
Also doing my CDL this weekend!
On a side note: Removing the gears from the main casing, I have a 2004 case that I pulled the front output housing on, but the gears don't want to come out?! Are those gears specific to the CDL, or do i use the ones I have in my truck and just bolt that new output housing on?
I have removed that top solenoid and the detent ball, and the gears won't come out of the case! I haven't really muscled it as of yet, just wiggled.
EDIT: Pull on the High/Lo Shift Rod, they come out once it is disengaged.
It's going to be a big weekend!
· Premium Member
There is no alignment you can do to correct this problem, have you gone under the truck and looked at all the bushings closely?
Discussion Starter · #7 ·
On it this weekend, I do realize that your can't align a solid live rear axle on this truck. I was more speaking to aligning the front, and just driving it to see what serious effect the rear half degree was making.
I will be giving it a work down in the garage.
1 - 7 of 7 Posts
