1 - 1 of 1 Posts
Newbie Disco Owner 2016
Hi All (Newbie here).
LR4 Disco SDV6 2011
After requesting a check for a small oil leak I have been advised that the Rear Cam Seal associated with the Drive for the Fuel Pump is leaking.
Part and fitting is apparently no problem or major cost BUT Got to get the engine out to fix it apparently (25hrs labour & much $$$$$). :crying
Has anyone experienced this seal going or has needed to get it fixed and is it possible to do without removing the Engine or the Body shell as has been promoted as the only way to do it.
Apparently drive belt is relatively easy to fit Blind by touch, however the seal needs full access ?
Thanks
Roscoe
1 - 1 of 1 Posts
