Rear screen defrost...
Hi,
Before you go any further check the connections on the window itself.
Also check that the tiny element that runs back & forth accross the window doesn't have any breaks in it. It is important that there is a good connection coming onto the glass in one corner, then the current has to run all through those tiny lines, then it has to exit from the other corner of the glass.
Any bad, loose, crushed connections or any breaks in this circuit, then the glass defrost will not work,
Andy
