1 - 6 of 6 Posts
Support Our Troops
I had the same problem with my rear hatch door. I let it sit for a few days and then it opened after a few tries. You can pop off the land rover cover and spray some wd-40 in there and it might help it open.
Forward!
Try the above mentioned that should do the trick! To get the little LR emblem off just use a thin flat blade screw driver to prise it out, then spray with WD40 or Tri Flow.
Good luck! :wave:
1 - 6 of 6 Posts
