I like my SLS, please don't advise me to switch to springs. I tow a boat regularly and the SLS pays off every time I tow.
I walked out to the Disco this evening and noticed the rear was sitting a bit low. Up until tonight, I've had no issues with the rear SLS - it's worked flawlessly. Yesterday, I heard the system letting out air as my passenger and I stepped out of the truck, indicating that the height sensors are still working.
So, here's what I've done to troubleshoot the system:
I opened the window with the engine running and with the engine off while pressing the SLS button on the dash. I cannot hear the compressor running.
All fuses look good. I didn't check them (or the relay) for continuity, but when I pulled them the SLS warning light came on, so I'm assuming the fuses and relay are fine. I don't have an ABS/Three Amigo warnings (it seems the SLS is tied in with those systems via the fuses), so I think it's safe to say the fuses and relays are fine.
My truck isn't leaning to one side, it is even, so I'm thinking the airbags are fine. The height has been steady after driving around for 10 miles.
When pressing the SLS button, the off-road mode SLS lamp lights and I get three beeps, but it goes out after releasing the button.
I have no warning lights on the dash and the rear suspension doesn't seem to have dropped after driving the truck 10 miles.
I have a feeling that my SLS compressor is shot. Can anyone reaffirm this?
- Pressed SLS button to put into off-road mode while in park, drive, and every other gear, and repeated in low range. The SLS compressor never activated.
- Checked all doors, rear door, and hood, to assure they were closed. The interior lights dim as the last open door is closed.
- Pulled fuses and relay that allow SLS to function. The SLS warning light activated in the dash each time I pulled the fuses/relay.
- Drove the truck around ten miles. There was no change in the rear suspension height.
