My left rear tire seems a bit more worn than the others. Is this a bearing issue? Sometimes I feel a little slip in back and not sure if tire is slipping or something else. Any suggestions? 2010 LR2
Your description sounds like an alignment problem, a loose or bad bearing will usually give you a notable noise. Check for obvious loose, misaligned or damaged components. Wheel alignment inspection
