1 - 3 of 3 Posts
'04 Discovery... I replaced the rear wiper arm and blade, but now the wiper only makes contact with the window in the center where the arm is. The 2 ends of the blade miss the window. From all I can see, the blade is attached properly. The blade is made of plastic, so there is no way to bend it. Any suggestions for adjusting the blade?
It happens with aftermarket bits quite often, if the arm and blade are genuine you can try to replace the spindle's grommet + washer and tighten it to be in the middle cos if the grommet is worn the whole setup can become missaligned, (nr 2, 3 in this link : Allbrit.de - Ersatzteile für LAND ROVER & MG ROVER )
1 - 3 of 3 Posts
