Thanks for the idea. Pulled that fuse and plugged it back in. No change. Any other ideas?Check fuses in the engine compartment unplug this one and plug it back in
I tested the 50 amp fuse you referred to that is in the engine compartment fuse box and it is OK. I also tested the fuse in the fuse box under the steering wheel and it is also good.Just make sure the fuse is not blown the remote recover is in front of the rear sunroof look under the steering wheel take of the cover and look for the key remote fuse pull it check it and plug it back in
If I could do that, I would. I think I need to go to the dealer, though.Maybe reprogram the remote?
Focus:
You could try one more thing; the EKA (Emergency Key Access method) which requires a four digit key code. If you don't know it you can get it from a dealer with proof of ownership and a VIN number. Follow the method on the attached image and see if you can gain access!
No idea, but just to be sure...you said you put in new batteries....Does the light on the key fob light up when you push the button? There should be a little red light on it when the button is pushed. If they do than you should be able to rule out that it's a transmitter/key issue and something with the vehicle.
Could the key fobs have somehow lost their programming?
