hi...i'm tryin to get a better approach angle by removing the front air dam...can somoebody tell me how to do this...or will i have to get new bumper or what?
thanks
On a disco 1, you will remove the airdam from the bumper, and cut the bumper end-caps at the crease to make it look right. About 1hour's work including cleanup.
It looks right, there are some pictures circulating.
I Just finished up. It took me all of 30 minutes. The nuts came off easy, Cutting was a snap with a dremel and sanding and steel wool to finish the edge off. The crease makes it easy, there is almost no way to mess up! Thanks to all!
Is it me or does the Disco just plain look better without the dam?
Now what to do with these factory fogs I just had to have, ...
I'm just thinking out loud. The existing bolt shafts that secured the dam in place are embedded in the bumper and they're set in a symmetrical fashion...Is it possible to fabricate a simple bracket for those fog lights from these boltshafts?
The original Disco plastic fogs are IMO more for sporty looks than real lights. I wouldn't bother re-mounting them. I think even the Hella 500 fog puts out as good a beam, ... no mask and thus ambiguous cutoff.
my buddy took his air dam off his suburban...and we realized it was there for a reason...to keep air from flowin through the suspension and making an obnoxious whistling noise while your driving....does this happen?
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
