1 - 2 of 2 Posts
Hi
i see two groups of bolts connecting the back end of the rear drive shaft to the differential. one group of 3 and a second group of 4 bolts. which group should i remove to most easily separate the back of the shaft from the differential.... the three or the two or should i take off all seven back there at the dif.
the manual mentions a flexible coupling flange back there and pinion flange.... whatever that is ..
I am putting the front of the rover on a tow dolly and want to separate the drive shaft
thanks
· Premium Member
Doesn't really matter. Just make sure you mark it so it goes back the same way.
1 - 2 of 2 Posts
