I just recently pulled the entire drivetrain out of a 2001. Engine definitely comes out the top and I did engine and trans out separatly. Trans out the bottom complete trans and transfer case assembly. Pretty straight forward. Have you ever done an engine removal before? Trans and transfer case are heavy I was surprised. Weighs more than the engine for sure
Thank you for this. It didn't occur to me that the transfer case and transmission are an integral unit. I can see they would be pretty heavy. I have a 2 ton engine hoist, but that weight capacity diminishes as you extend the boom.
I've removed engines from cars, but never from a truck like this. The strategy with the old Triumph sports cars I normally work on is to remove the engine and trans as a unit. In this case, I'd be just as happy to leave the trans in the truck provided they can be separated and reconnected fairly easily. The engine itself should be quite light.
Is it safe to assume I'll have to remove the intake plenum and coil packs to gain access to the upper bell housing bolts? I also assume I'll need to remove the bonnet for clearance.
I'm getting a handle on this truck's many issues. The list of things to fix is getting shorter, but I'll enjoy driving it a lot more once I get its oil consumption problems under control.
