Doing ABS Option B Mod
Doing the ABS mod described in the sticky and have run into a few snags...but figured the first few out myself. First the side plug didn't want to release. Pulled harder after flipping the clip up. Success. Then I couldn't get the seals off the plungers using my fingers or needlenose. Razor blade worked well.
Now it's the multimeter reading 0.00 instead of 3.00 open / 2.00 half open / 1.00 closed. Is this the root cause of my 3 amigos or something wrong with the way I'm testing. I tested before soldering (tested the brown wires directly) and after (tested the trailer harness).
